Late arms
colin944
Has anyone got a passenger side late arm S2 or turbo. I need one don't care if ball joint is gone as I will change it anyway. I'm in the middle of doing my ball joint and discovered that the passenger side has been machined out to take a different joint at some point. So can't fit replacement joints. So I need an arm. Pm me I need one in a hurry.
951.341.027.02 (or 951.341.927.31)
From a 1987 model year to a 1991 model year car. 951.341.027.00 is an 86 and is completely different and parts with a 944 prefix are from a 968 and have different ball joints.
HTH
A big thanks to Paul Heath who called me with an offer of arms .The problem I had was that the passenger side arm is a replacement that has been machined out on the ind=side and had a steel sleeve pressed into it. It looked like they had machined a golf ball joint down to a sleeve and pressed that into the arm. the whole thing had then been pumped full of chemical metal and sealed with more chemical metal. It was a total mess!! So we took a new golf ball joint and machined it down to make a new sleeve which we then pressed into the arm which allowed us to use the brass insert from the Rennbay kit and the rest of the kit as well. I now have two arms with the same ball joints in them. Although I am still going to get an original arm and fit a new rennbay joint to that one.
