Have had several complaints/advises, depending on who I speak to, with regard to the non appearance of my brakes lights when braking!
I have been able to prove that the brake lights work ok, but are simply coming on late!
My Haynes manual waffles on a bit, but eventually points you in the direction that on the carrera the adjustable switch is done away with, and the lights are actuated by hydraulic pressure on the brake master cylinder. It is suggested to bleed the brake system to rectify the problem....can anyone confirm this please?
The fluid was changed a couple of years ago, and the brakes feel fine.
