scam75
Well-known member
Hi Guys
As you'll know from my main engine build thread, I'm chasing a low-ish oil pressure issue and will most likely be removing the OPRV to check it (if indeed a proper gauge agrees with my dash readings).
Does anyone have the tool they could lend me to check alignment? Failing that, if the OPRV goes in and out without much bother, we could assume it's lined up ok?
I'm waiting on a reply from my engine builder to see if they removed and re-fitted the oil cooler housing when they had the block, and if so, how they lined it up.
Thanks in advance
Stuart
Thanks in advance
Stuart
