Unless your using your Porsche for essential journeys during the lockdown period, it makes sense to lay it up until things become a little clearer.
Here are few suggestions on what to do:-
Vehicle Excise Duty: - It makes sense, if you're not using your car on the road to SORN it until such time as it can once again be used.
Insurance: - Some companies will consider "laid up" insurance during the down period, otherwise reduce cover to third party, fire and theft for a premium refund. My renewal is due next week and interestingly, in my case, it was cheaper to go for full comprehensive. TPF&T proved dearer due to there being no excess discount. But I did manged to knock a 100 quid off the premium by removing a named driver and adding £150 voluntary excess. (PCGB'S official insurance broker, Lockton quotation was more than double the premium I am paying.)
Cleaning: - It pays to give the car a good wash including power washing wheels and wheel arches. Dry everything off and avoid corrosion. A leaf blower on metal brake discs and under-floor components is beneficial. []
Condensation: - Fill the fuel tank and leave a couple of small bowls of dry rice inside the cabin to absorb any moisture. Keep a dehumidifier running if possible and WD40 bare metal components, locks etc.
Electrics: - Leave a smart charger connected to maintain battery level. (There's a section on CTek chargers in 991 Register forum - click here).
Tyres: - Pump these up to reduce the contact patch and occasionally roll the car back and forth over the forthcoming weeks.
Wipers: - Pull them off the windscreen to prevent sticking or wrap them in cling film.
Leakages: - Slide a drip tray under both ends and any leakage will become easily identifiable later.
Handbrake: - Leave this off and the car in "park”. Manual transmission leave in low gear with the wheels chocked.
Engine: - Check all fluid levels and intermittently fire the motor up until warm.
Paintwork: - Use a good quality dust sheet to prevent swirls and scratching.
This disruption won't last forever and hopefully we'll all be back to normal and enjoying our cars again very soon. []
Regards,
Clive
Regards,
Clive
