scam75
Well-known member
Hi All
My temp gauge often needs a little kick start to get moving, either that or go over a few bumps! Flicking the dash pod acts as a kick start. Odd, so i thought I would change the gauge. My other gauge does the same. Next I cleaned up the little contact prongs at the back, no change, swapped them out, no change.
Right then, next step was change over the binnacle itself in case of suspect circuit board. Still the same!!
Could I have two gauges with the same affliction? Has anyone else experienced this? It has to be something in or very near the gauge for the flick to act as a kick start but everything has been swapped over?
Hmmmm
Edit to add once the gauge starts working it is faultless.
Stuart
Hmmmm
Stuart
