LCD Clock Screen
zcacogp
Chaps,
I know it's a common problem, but the LCD screen in the clock in my S2 has cracked, and is bleeding. It still works, but look unsightly.
I have taken the clock out, and dismantled it, and the screen itself is easy to remove. (This is good!) It isn't soldered in, and if a new item could be procured it would be replaced very easily .. the snag is that I can't identify the screen itself. It has no identifying marks on it at all, anywhere, and is not of a common size. (There is a faint possibility that it may be the same size screen as is in a Mk1 Golf, but I don't have a Mk1 Golf screen here to compare it with precisely, and it seems that Mk1 Golf screens are not exactly in common supply either!) I have contacted VDO (who made the clocK) to try and find information from them, but they were downright unhelpful.
So, what next. I understand that you can replace them with a tempterature display from a 968, but this is very expensive - the temperature display units are as expensive as new clocks (unless anyone knows a good source of them second-hand.)
What has anyone else done when their clock has gone west? Any suggestions?
My current idea is to fit a small analogue clock there. I am looking at VDO items, and the standard one is a little bit big, but may fit. Perhaps. Does anyone know if there is a VDO-esque clock with a (body) diameter of less than 5cm?
ORIGINAL: zcacogp
I put some black electrical tape over mine [:)], hides it a treat until I find a replacement and the clock on the CD player does the trick in the meantime
One of my jobs for when the weather gets better is to remove the clock on mine, I never use it any more, I got fed up resetting it when I had battery problems and it will be no use when the little battery is fitted as I'll need to fit a cut out switch to stop if draining over night. I plan to do similar to Pauls idea, if I can find some black plastic that would be ideal, or if it doesn't look too naff I'll try a small offcut of carbon sheet.
I fixed mine by dismantling a spare clock from my other '44 which was broken in an entirely different fashion. Between the two knackered clocks I was able to put together one totally working one (and one totally useless one, I suppose).
Email me with the size of the clock. I'm in the process of rebuilding a Mk1 Golf so if the clock fits you can have my spare. (Bit of a waste of time as I actually own and use a watch!![:)])
Cheers,
Fred, YHM, thanks!
Poprock, that's a good idea, and a principle I have used to repair many things before (digital cameras with smashed screens, a pocket MP3 player etc etc etc). The snag is that screen bleed seems to be by far the most common mode of failure on 944 clocks, and I have yet to see one that is broken in a different way .... Where did you find the non-broken-screen clock you repaired yours with?
ORIGINAL: zcacogp
Sadly, I found it in my 944 Lux "¦ which means that I'll have to point out to any prospective buyers that its clock is now buggered!
