I had my 1988 Carrera 3.2 serviced at a very well known specialist back in October 04. It was a 6000 mile service so basically a check and oil & filter change. The car is showing a genuine 49k miles. The engine, prior to this service was absolutely leak free - no sign of oil leakage whatsoever. Car was run on 10w-40 semi-synthetic oil - last changed by me about 3k miles previously.
Before the service I had a conversation with them regarding the oil that they would use - Millers 5w-50 fully synthetic. I voiced my concern over the use of a thin and synthetic oil as I was worried about leaks. The specialist said that it had developed the oil in conjunction with Millers and reassured me that I would not get any leaks.
Guess you can see what's coming.
The engine is now leaking oil. I've used it precisely three times since the service, including the journey back from the service itslef. I now have three patches of oil on my garage floor.
The bizarre thing is that the car does not appear to drip oil stratight away. The last time I used the car (at New Year) I kept a vigil on the garage floor. After two weeks - no signs of leakage. Then I ntice oil on the garage floor after about three to four weeks. I've not had any opportunity to get the car up in the air, but the oil is dripping off the main crankacse joint (but I obviously don't know where it's coming from).
After I first noticed a leak I contacted the specialist and let them know I wasn't happy that my car was now leaking oil. The specialist is adamant that this is NOT due the use of the 5w-50 synthetic oil.
AM I just unlucky. Is it just coincidence that I now have a leak? Am I right to )in my mnd) believe the oil used is to blame?
I would value your thoughts and how I should approach the specialist in question.
