Leaking Rear Window
- Thread starter Guest
Gary71
You can reuse the trim strip if you are careful getting it out, I used a local windscreen firm to put the screen back in (with a new rubber). This is a right fiddly pain and took a experienced guy 3 hours!
Get the leak fixed or the parcel shelf fills up with water, then rots out the upper crossmember, then leaks down the rear seats, takes out the lower corners of the floorpan, into the jacking points and takes them out along with the back of the sill and the longitudinal under the torsion bar.....[&:] Guess how I found out...[
When refitting use lots and lots of mastic screen sealant, I spent many hours with a hosepipe and no trim in the car checking that it had worked. The worst leak was coming from the top of the seal where it changes direction to go across to top of the roof. The water ran down here the inside the seal to appear in the bottom corner before continuing to flood the newly repaired shelf
Check out the picture of the rot as I discovered it....
