Gentlemen and Ladies,
I have a 2000 Boxster which has been a dream of a car to own with little or indeed no problems... Touch (Head) Wood. Until now that is!
I have a leak on the passenger side that collects water behind the passenger seat, I have checked that the drain tubes in the rear compartment are clear and working ok and did actually extract a bolt from this side with the hoover.
I have used an aqua vac and sucked up all of the water until the carpet was touch dry and then a few days later the water is back again. When you pusch your finger into the carpet you can see the water. It is clear water with no odour or colour.
Any ideas as where it might be comming from and suggestion on cleaning any other drain like tubes or whatever??
Appreciate any help you could offer and welcome any suggestions, thank god the summer is just around the next but after the next corner!
Dean
Dean
