Just checking if anyone has had a situation where the front headlight has water leaking into the headlight. (The previous week there was alot of rain!) I can see the rubber is fairly rigid at 16 years old around the headlight and probably needs replacing. Can you replace the rubber or is it a complete headlight?
Leaky Headlights
- Thread starter Russell Wheatley
have all cars got these drain tubes from the electrical connector ? I don't seem to have any tubes, I have litronics though, don't know if it makes any difference. I pop my headlight units out by the way if I get caught out in the rain, or to have a good clean inside, and a squirt with some duck oil or similar to stop any corrosion in the housings . Have we got any an*l smilies []ORIGINAL: D Ward
Are you sure its not condensation? The headlights have a vent tube, out of the headlight electrical plug and down to the little black plastic things on each side of the pu,maybe one or both of these tubes is blocked or twisted trapping moisture in the headlights
