leaky rear screen
- Thread starter Guest
Diver944
Do you get a puddle on your spoiler? Check that the two drain holes at each corner are not blocked and causing a buildup.
If it is coming through the gap where the frame closes onto the rubber seal that is attached to the bodywork then this is very easy. A new seal is £29 from Porscheshop. Don't cut it if it appears too long. Place both ends onto the lip above the number plate and then work your way around the boot in both directions, leaving loose bits every foot or so until you finish at the top of the roof in the middle. Then go back and push down all those loose bits.
