Hi all, whilst trying to fix my broken wing mirrors i had cause to remove the interior door trip on my 89 S2 cab. Whilst doing that, i noticed significant damp on the panel and the metal work. Now i know for certain that my S2 is not completely watertight but dont really want to go through the hellish expensive seal replacements. Is there a quick/cheap/nasty bodge that will help me seal things better. or is there a source of cheap seals?
Im not too concerned about some water ingress into the cabin as such as that quickly dries/evaporates - my concern is the water being trapped between the metal work of the door and the interior door panel as this soaks the fibre board of the door panel and must be weakening it as i suspect it never really dries properly. Would a bead of bathroom silicone sealer (or similiar) around the edge of the door panel help stop water entering behind the panel? I was thinking of using it almost like an adhesive and applying it as a thin bead about a 1/4" in from the edge of the panel and then refitting the door. Or is that just daft as the sealer wont stick to the metal work etc? and i suppose it will give me no end of grief should i ever have to remove the panel again.
Any advice would be most appreciated.
