The offside front Speedline has started to leak. It was fine when fitted in the spring. Dunking it in the bath when no one else was looking has revealed a leak from the rim to wheel centre seal on the exterior face for a short section between bolts 10 - 14 inclusive (anticlock from valve).
I propose to check how tight the split rim bolts are, but would appreciated info on the correct torque setting and also what the correct type of socket is required for the external bolt heads.
Any advice would be appreciated - including the name of a suitable specialist to overhaul the wheel, if that is the best approach.
Happy new year to you all.[FONT=Arial"]
