leather seat repair kits
garyalanlane
Finally thought I'd post a few pictures and details of the leather repair and re-die from my interior. When i purchased the car it had a rather worn looking dark blue interior. The driver seat bolster had three nasty looking rips. I thought about going for a complete re-trim but the costs were horrendous. I then looked into the leather repair and re-die kits you can get on the internet. After looking at various you tube video links on the procedure I thought I'd give it a go. After taking the seats out first you rub them down with a solution that takes of the top protection layer and some of the old die. This gives the new die some thing to key on to. This was a very messy job. Then you have a special compound to repair the rips. First you lay some hessian behind the rips and glue the edges down. Next you slowly fill the rip in with the compound which is a kind of very wet putty. You slowly build it up layer by layer until it sits proud of the suffice. Next you sand it down until it's level with the suffice trying not to sand too much of the surrounding leather away. This is a very slow process and it took me many times to get to a reasonable state that I was happy with. When I was finally done with all the filling and sanding it was time for the re-die. I decided to go all out and completely change the color from dark blue to light beige . I had the firm custom match me a color of my choice. First you dab the die which is more like a very very thin paint all over with the provided sponge and leave to dry. Then you slowly build up layer after layer by spraying on the die with the hobby air gun provided. This turned out to be very slow and nearly useless. I'm lucky enough to be in possession of a compressor and spray gun so i used this instead. All though this gets the job done quicker it is much more thirsty on die. I used 5 liters to do the full interior all though i did do the dash, door cards and center console as well.. The hardest part was between the back and bolsters and seat back and cushions. I had to press down with my knee to open the gaps between cushions and bolsters and spray a little at a time, drying with a hair dryer before releasing my knee so the two parts did not touch and stick together. What a pain in the A****. I lost count of how many coats of die I sprayed but it was at least six. Finally I sprayed on a protective sealant which gives it a gloss, matt or semi matt finish. I then did the lower door cards, lower dash which I replaced because the old one was cracked and the center console. I finally replaced the whole interior back in the car while adding a new illuminated gear lever, blue illuminated leds in the instrument cluster and air con controls, some aluminum instrument bezels, a carbon fiber dash kit and a new steering wheel. The whole job took two very long days to complete I know some of you may think its too bling for their liking but I just wanted to show what could be done with £150 worth of leather repair kit as apposed to a £2000 re-trim.
Looks really good and much better than the old blue interior [8D]
How confident are you that it won't rub off under use and reveal the old blue [:eek:]
It's been done about four months now and I take it out at least once a week and apart from a little damage on one of the seats to the beading when I put it back in the car, I've had no problems so far. The sealer is quite hard waring and since I bought plenty of die and sealant I could all ways go over it again, but I'm quite confident of them holding up. I think like all leather seats it will wear off with use. Leather repair kit came from http://www.furnitureclinic.co.uk
Gary
Looks great - can you be specific about the products and quantities you bought - would you recommend buying a better compressor?
Slightly OT but are the base bolsters different on sports seats c/w comfort seats?
The back bolsters obviously are but I assumed the base wasn't. Looking at those pics I'm not so sure now.
I bought a single sports seat of ebay thinking I would simply swop the back and see if I liked it before splashing out on a new pair but it might not be a valid experiment.
That's a great job Gary - lots of hard work but it's really paid off. [:D]
I might be a bit picky, but wouldn't it be nice to get a decent Momo wheel in there as well?
ORIGINAL: DavidL
Yes the base is different. On sports seats the squab extends further forwards than it does on a 'comfort' seat.
Cheers guys. I bought the basic leather repair kit, 5 liters of water based color and two liters of matt sealant. The kit came with compressed air canisters and a hobby air brush. I used a normal industrial compressor and a professional spray gun. As far as I know the sport seat bottoms are slightly different than the comfort seats as in bigger bolsters but I see no reason why you couldn't swap the two around. All the fixing points and width should be the same, but don't take my word on it. On the steering wheel note, yes a mono would be better but my one was under £80 with the boss and lovely to drive with and leather.
Can you re-colour the vinyl bead and seat backs with the dye too? Id like to refinish a set of grey-beige series two leather seats that I have, but the vinyl colour will restrict my colour choices.
ORIGINAL: Diver944
And what's wrong with a blue interior...?
I actually quite like my '80's retro cool ' Blue Pin Stripe Interior
Yes the die goes on leather and vinyl. But you must follow the instructions to the letter as I rushed the first one not doing every thing properly and the die came of some parts within days. I had to do it again properly and as I mentioned before It's held up very well. I think the most important part is the sealer. It's a very slow and messy job not for the faint hearted but the results speak for them selves
Great result of all your hard work. Mine needs re-dying too so I might get brave one day and give it a go. I'd like to get a more consistent colourway going in the car as I've got black, dark blue and linen/cream - I could happily do away with the blue parts.
Those wheels are Awesome, who makes them? how big are they? they look really nice!
This is definitely my favorite 944 ive seen :)
Dann
Looks good. You must be very pleased - well done.
I'm going to be interested to see how it holds up to sustained use; how will it look in five years time?
I'll admit to being tempted by something similar on my linen interior - re-dying that would make it look at LOT better. Nick (appleton) had his done in the same way (but professionally) and it was transformed.
The wheels are Victor Equipment Le Mans who make wheels for only porsches. As other forum members will no doubt say mine are probably too large at 8"x19" and 10"x19" but I've had no trouble to date. I have had all the bushes etc etc upgraded though. My car sits on MO30 lowered suspension but I didn't have to do any body mods, and I never get any rubbing etc even at hard cornering. If I was to buy them again I would probably go for 18's purely on what people have advised, although this opinion doesn't seem to be shared on a certain other forum the other side of the pond. Victor Equipment do wheel sizes 18"-22"
ORIGINAL: evoboy69
Purely personal preference, I don't like dark interiors - too gloomy
