I’ve recently installed LED dip and main beam bulbs into my 987.2 Boxster and am getting error messages saying check left and right main beam bulbs. I realise this is due to the much lower power taken by the LEDs and the conventional fix is to add load resistors.
Take one step back to the bulb purchase. I first bought dip beam LEDs from HIDS Direct, and they are perfect, very bright, great colour and totally error free.
Unfortunately HIDS Direct couldn’t supply main beam LEDs small enough to manipulate into the ridiculously small and awkward access to the main beams. The only ones I could find of the same overall dimension were on Ebay and even they were a struggle to install. Disappointingly they aren’t nearly bright enough and worst of all give dash errors.
I have purchased 100W resistors and even though they are quite small I can’t find anywhere to fit them and still get the headlight units back into the wing!
can anyone help me find better brighter LEDs that don’t give error messages or failing that tell me how and where to fit suitable load resistors and what wattage they need to be.
Thanks in anticipation.
