Any recommendations for repalcement LED lamps? I have rear LED number plate lamp which is very effective and would appreciate similar for Headlights, fixed headlights and fog lights.
LED replacement lamps
- Thread starter chrismunro
Chrishazle
Would be surprised if headlamps are possible as they're twin filament, also all 3 you're asking about have reflectors designed for filament lamps so not sure they'd work with LED's. I've changed sidelights and most of the rear lights for LED's OK (except indicators, where LED's caused multi-flashing as per bulb failure) but have yet to hear of anyone here or on 968uk changing heads, driving and fog lights.
Waylander
There are some serious H4 LEDs available, but they won't go in the hole because of the pods of the headlamps
standard H4 is about 700 lumens the led replacements go up to 7000 lumens
the fogs and driving lights can be replaced with LEDs try woodpeck.com they have a good selection
H1 and H3
the indicators are a bit of a problem as LEDs do not provide enough load for the relay to function correctly, you will need a electronic flasher relay
H1 and H3
