poprock
I'm dropping my car off tonight at my usual independent specialist garage. It's one of those visits with a long list of little niggles to fix that have added up to the point where I want them all sorted in one go.
I thought it might be fun to see if anyone can guess the causes of some of the problems, or make a guess at the total bill I'll get at the end. I'll post the actual results when I get the car back.
Here's the list:
Door handles: Swapping for a set of nice scripted ones. The job has proved beyond me, because of the extra security panel inside the door on my model year. Swapping the lock barrels over, so that my existing key works in them, and repairing the central locking.
Window scrapers: Supplying and fitting new outside scrapers while opening the doors up anyway to do the handles.
Oil leak: I have a nasty oil leak. We've replaced just about every oil seal on the car, so this time the suspect is a small piece of pipe which turns out to be a main dealer only part.
Bushes: The oil leak has been dripping on one of them and the rubber has deteriorated a bit. If the damage is bad, it'll be time for replacements.
Gearchange: My gearchange isn't as smooth as it was. It's downright awkward; going into and out of the middle gears (third and fourth) is no longer one smooth motion, but requires a definite shove to the centre and then up/down into place. Not right at all. What's wrong there then?
Mystery rattle: I have an unidentified metallic rattle from the rear of the chassis. It's not a CV joint noise, more like something lightweight flapping about when driving over rough ground. I've been unable to locate the source. Any ideas?
Rear brake back plates: My last MOT included a note that they were in poor condition. Time to just take them off then, I can live without. Could it be one of these that's causing the rattle mentioned above? Or is that too convenient?
Here's the list:
