Hi. I have a LHD RS and it has the original headlamps fitted with a semi-permanent sticker for RHD conversion. One lens has a big(ish) stone chip so I was thinking of replacing the lens and fitting a pair of RHD ones.
Question I have is in order to correct the beam and pass MOT etc is it sufficient to fit the RHD lens or would I need to change the entire headlight unit? There is quite a significant difference in cost and my headlights work fine at the moment.
If any of you guys have done the lens conversion with success (or failure) I would be interested to hear.
