The rear fog lights on my '87 3.2 will only come on when the front fog lights are on. It this normal?
Also, the lights behave in a way which I'm not sure is correct. There is no difference (to the head lights' behaviour) between the knob out one click (the green side light indicator now on) and right out (two clicks). In both positions the main/dipped beam is on fully. However, the fog lights won't work unless the knob is right out. This seems wrong, as it is common to want to drive on side lights, with fogs, in very foggy conditions. I have no option to drive on sides, let alone with the fogs on.
Also, with the knob right out, there is no difference between the ignition fully on, and the position before that which allows the radio to work but not the engine. The lights are fully on. A friend with a 3.0 Carrera says his also work like this, but maybe his are wrong too!
I recently had to rewire the light switch, in order to replace the dip/turn switch, and maybe I didn't wire it back up correctly. Before I dive in again I'd like to know what's normal.
TIA,
Jon
TIA,
Jon
