Light switches
- Thread starter John H
SteveSJS
As nobody else seems to be answering this one I'll try...
In the past I've used a very wide flat bladed screwdiver, very gently. The switch itself is mounted with two spring steel clips - one at either end of the short sides. But I'm not an expert and I've usually only done this when I've taken the door card off first. The ones on the centre console work the same way.
HTH
SteveS
