ORIGINAL: 944Turbo
ORIGINAL: Diver944
ORIGINAL: Ellisd
I originaly was thinking of getting the electronic boost controller and just using the boost but then i remembered that the fuel would need changinf as well
This is one (of the many ) things I don't quite understand.
If you have a MAF or MAP which has been mapped for a max of 1.5 bar of boost but you turn the boost down to 1 bar, surely the sonsor now measures that you only have 1 bar and dispenses the fuel accordingly [&:]
The standard AFM (barn door) maxes out (fully open) at about 4,000 rpm after that it is relying on the programming on the chip in the ecu to approximate the fuelling/ignition relative to the rpm/ throttle position.
A MAP or MAF can allow the the airflow to be measured more accurately all the way through the rev range.
Most MAFs for the 944 replicate the original air flow meter signal - i.e. maxing out at 4,000 rpm then relying on the chips to have pre programmed guestimates of fuel/ignition for each combination of throttle position / rpm (or custom chip developed on the rollers)
The vittesse MAF/chipset allows incoming airflow to be measured all the way through the rev range so the fuelling can be maintained correctly more like an aftermarket ECU (Motek, etc etc.). Though with MAF or standard AFM if you have a boost leak after the incoming air is measured you will still run rich.
After market engine managment with MAF should allow the same (measurement of incoming air throughout the rev range).
After market engine managment with MAP looks at the pressure in the inlet manifold and converts this to info on the amount of air going into the engine (measurement of air throughout the rev range). This will also compensate for boost leaks, dump to atmosphere dump valves etc.
The link MAP kit (guru) tried to convert a MAP signal to replicate the standard barn door AFM. I believe the promax (chip wizards) MAP conversion does the same more reliably using BMW components.
Tony
