Location of Tyre Pressure Label on 996 door jamb
dbrich
Hello,
I have bought a genuine Porsche door jamb tyre pressure label for my 996 tiptronic cab, model year 2001, but struggling to find out where this label should be fitted. If anyone can either describe or send a picture showing its location on the driver's side door jamb that would be much appreciated. I suspect that the original label was removed as it looks like the door latch area has possibly been re-sprayed.
Thanks.
Hi,
This is interesting. I have a 1998 C2 coupe and I don't have a tyre pressure sticker on either door jamb.
I'm pretty certain the car hasn't been resprayed so I'm not sure that the car ever had one.
Gerry
Cheers Richard,
I hadn't noticed it there either but sure enough it was.
Thanks for answering this.
Gerry
I'm the same, no foil sticker with tyre pressures on either door jamb ,but it is stuck on the underside of the front bonnet (99 C4)
Thanks to all the replies, much appreciated.
I have the one under the bonnet so ok on that front. I ordered the door jamb one based on the PET pictorial. Luckily it only cost £5.95, unlike the vin plate at £238 !!!!
Dbrich
