My Boxster is still quite new, under 10,000 miles, I went to fill up with fuel and my flap wouldn't open!. There is an emergency lever but now it won't lock. Anybody know the cause, there doesn't seem to be a fuse for this?
locking fuel flap won't unlock
- Thread starter rphennessy
The fuel filler flap lock works with the central locking, so it'll be on the same fuse. If the central locking is working, then the fuse isn't the problem.
It's possible that the little pin that comes out to lock the flap has got jammed with dirt or something, (have a look for anything obvious and try a squirt of WD40 or similar).
Other than that, it could be that the actual solenoid actuator that drives the pin in and out has either failed or has a bad connection.
[] Many thanks, the fuse wasn't the issue as central locking for doors still worked. So squirted WD40, and fidelled with pin and left a day, now all working.
Appreciative Boxster Anniversary owner.
I should have asked about the emergency fuel cap release (inside the wheel arch), I had to use this to unlock the cap. Will it work again or does it have to be re-set by Porsche?
Richard
Richard
