colinbythesea
Hi all,
After a couple of 924's and a 944 over the years, I have just bought a 2000 2.7. It is in good condition with a Porsche main dealer history. There are some things that I would like advice on before I try to get non existent faults fixed.
The first is very weird. The central locking works OK as long as I am near the window with the key. Only one key works even with new batteries in both. The strange thing is it just doesn't work for my wife. We have spent a lot of time with her replicating the way I use the key to no avail. At the weekend my wife's father had a go, no problem. Her step mum couldn't get it to unlock. Initially this has been funny as we suggest it's a mans car but the joke has worn thin now. It doesn't work from a long way away like my Focus does, however, was it still infra red at this time not radio. Anybody had anything similar and should the key work from a good distance away?
Secondly, the car had a new water pump due to a worn bearing and coolant leaking out according to the last Porsche centre receipt from a couple of months back. When I drove it home it decided to drop a bit of coolant from the pipe that exits above the offside rear suspension at the end of the journey. The level in the little window to the coolant in the boot showed minimum. I have not topped it up as it shows just below minimum cold and over maximum hot. I haven't noticed it drop coolant since and runs at a steady temperature even in slow city traffic. My old 944 used to dump some coolant if it was filled between the minimum and maximum but was fine left just below minimum on a cold engine. My own thoughts are a worn pressure cap on the coolant system, any ideas?
The car has a 3 month AA warranty so now is the time to get things checked.
Apart from this the Boxster is a fine car and very different to the 944 I had. Not sure if I like the almost invisible engine yet. I'll take the cover off soon just to have a look. I will also change my picture on the left when I take a good one of the Boxster.
