Locking Wheel Nut Keys
johncolt
I only have one locking wheel nut key, which is a bit dangerous as it's already a bit bent. I have tried several locksmiths but none are able to cut one, plus it is longer that any normal key. What is the best way to source another one please?
John,
There are only a limited number of key patterns for the locking wheel nuts and, apparently, the OPCs keep a full set. I suspect that should be your first port of call to see if they can order you up a new one.
Dave
I think he means these;
http://www.type911shop.co.uk/shop/article_4007/Porsche-Wheel-Lock-Key-Blank.html?shop_param=cid%3D802%26aid%3D4007%26
You would do well to bend a socket!
Dave - Excuse my ignorance but what's an OPC?
T911UK - My key is of this pattern but much longer, presumably to reach into the wheel nut recess. I don't get your comment about bending a socket!
Both the Cambridge and Ipswich Porsche Centres say that these keys are no longer available. However the Type911Shop do have the blanks, one of which I have ordered. Many thanks.
