One of the problems I didn't mention in my list http://www.porscheclubgbforum.com/tm.asp?m=119000 was that the front o/s locking wheel nut is stuck/sticking. I'm afraid that I tried attacking it yesterday with a combination of a rubber mallet, WD-40 and various sizes of screwdriver! I managed to remove the centre barrel containing the locking mechanism, but the outer casing remaind in place. With quite a lot of coaxing and some minor damage to the casing (why is it made of a metal only slightly harder than cheese?) I eventually managed to pull that off the bolt. However, it does seem very stiff on the bolt itself, has anybody else had a similar problem (the entire assembly comes off as a single unit on all three other wheels.)? Have I knackered it by managing to pull the centre locking mechanism from the outer casing? Any advice greatfully received.
Cheers,
Graham
Cheers,
Graham
