Looking at a 964 Convertible Today
Mutley
Hi chaps I am looking at a 1990 964 Convertible later anything I should look for in particular, it does have the usual slight oil leak but apart from that it looks good, thanks
If you think it is good and you want to buy it make sure you get a ppi done by a professional as it could save you ££££ in the future. Check everything you can tyre conditions/uneven wear. Smoke from exhaust although a little on start up is normal. Check every electrical item, air con if fitted etc. Check to see if clutch flywheel etc has been done. Check service history and telephone garages to check that the work has been carried out.
Hope this helps a bit
Tim
