Eiger
Hi All, I'm trying to get my 16vS engine to run right.
I'm not able to rev above 1600rpm without the revs dropping suddenly and then surging up again.
I double checked the crank - camshaft timing/TDC and it's set correctly.
I sprayed WD40 into the ICV under the manifold through the front aperture after removing the hose that runs to the bottom of the intake, as I've read they can stick. No difference once reconnected and left to idle. When I try increase revs it hunts at 1600 again.
I've also tried running with the TPS disconnected but the symptoms were the same... Still won't rev above 1600rpm before dropping back, then climbing up and so on ...
What else can I check?
Thanks to anyone who can help me get my 944 running again!
