Just wanted to add some recent experience with my 928 S4 that might help other 928 owners with AUTO's avoiding trashing their engines.
After only 5500 miles since the flexplate pressure was released, the issue started again. At first, a strange buzz/electrical type noise began that sounded like it was coming from all over, mid-way under the car. Initially I did not suspect flexplate pressure as the noise sounded electrical/like a failing fuel or power steering pump. After a week of local driving the buzz had changed tone and sound type, into a wurring; like a jet engine winding-up or something similar; it was now clearly coming from near to where the engine under-tray ends under the bulkhead; I now realized to my horror, it was flexplate pressure.
I had it over to Steve Bull Porsche Specialist a.s.a.p and drove VERY slowly at max 1500rpm. Releasing the clamp showed 2mm movement which equates to a lot of pressure on the flexplate under load/at speed. I had the old clamp removed an upgraded one installed to stop any future movement;
http://jenniskens.livedsl.nl/Technical/Tips/8/MyTip818.htm Theo has had one of these clamps on his 928GTS for 6 years without any movement/pressure occurring.
ALL wurring has now ceased and I can relax driving the car again! If you own any 928 AUTO and hear similar noises/sounds get the flexplate pressure checked a.s.a.p, as continued driving with FP pressure can trash your engine and/or the TT bearings at great expense.
Cooling Air Flap control system. When I bought the 928 S4, the front cooling flaps inside the nose cone in-front of the RAD were fully open and tie-wrapped in that position with the motor linkage to the flaps discarded. My around town mpg was 14-15; long journeys 18-20mpg, and my engine took a long time to warm-up fully in winter and around town. After reading much debate online about the use of these flaps and the pro's and con's of them, I decided to see if I could get the system working properly to see if they do help drag reduction/engine warm-up.
I cut the tie-wraps, replaced the fuse/relay/linkage and function tested the system using the Porsche S4 manual as a guide. There was a fault with the a bad contact at the fuse box and ground connector for the control module beside the passenger seat, so these were corrected. The system now works properly.
This is what happens now: at cold, the flaps are fully closed with the fans off; at 90 degrees the flaps are 30% open and the fans cycle on/off intermittently; at 95 degrees + the flaps are 100% open and the fans at full speed. With the engine warm and turned off, the flaps open fully. Mostly, in most normal driving conditions, the flaps are either fully closed or in the 30% position.
My engine reaches 80-90 degrees within 2 miles of driving now; my town mpg is 16-18 and long journeys 22+. I haven't made any other changes to the car in this test. So, in my experience these flaps do improve mpg which must be due to the faster warm-up and reduced drag with the flaps closed or at 30% in most normal driving situations.
The main point to bare in mind; when the system is working OK it is fine and beneficial. If you do get any problems with flaps staying shut leading to over-heating, use the manual over-ride on the control motor under the hood for the flaps to open the flaps fully, pull the linkage from the motor, and tie-wrap them securely until you get around to fault finding what the problem might be. NEVER leave the flaps fully open without the linkage in place as under air pressure they will close at speed!
hope other 928 owners find this info of help.
