paul reade
Took the 986 3.2s , 2004 model with 34kmls out yesterday. Dashboard lighting failed whilst out as did the rear number plate lights. All other lights ok.
Had a good look over today and noticed that if I take the 2 bulbs out of the rear numberplate light holders the dashboard lights reappear ?????.
The fuse is obviously ok, the bulbs are not blown albeit they are slightly blackened, and having stripped out all the rear boot all seems ok. If I return the bulbs to the holders the lights on the dash fail and the lights on noise ceases to sound ????.
I have 12v at the number plate light holder and I cannot think what has occurred to cause the problem. The problem happened over the days drive with intermittent dash lights coming on then going off. Not sure what the other wire (brown) - grey has 12v, on is connected to - is it the chassis as I have a very low ohm's reading but it does not appear to be a direct short.
I am based in the north west and can take it to an auto electrician if anyone wants to recommend one to me.
Hope someone can throw some light on the problem (parden the pun).
regards
Paul R
regards
Paul R
