Lost or Stolen, missing warning light ?
Technical Question
Relevant Model: 964 C4 Cab
Question: Can someone help me? I seem to have lost my big red warning light on the dashboard. It has stopped working together with the " handbrake on" warning light and petrol warning light. I have checked all the fuses in the fuse box, they are all OK. Is there something that I am missing or a hidden fuse somewhere? Everything else seems to work OK.
Thanking you in anticipation. Simon Diliberto.
The most obvious thing to my mind is the bulb has gone.
That is if the warning lights are illuminated with bulbs - the handbrake one is probably the one most often used.
If they use LEDs then it is less likely.
The other thing could be the switch on the handbrake itself.
The petrol light seems less obvious.
