Hi there,
I usually post in the 944 forum, but I moved my dads '83 924lux the other day (I put my 944 next to his 924 in the garage [
]) and i noticed the idle seems to be a bit low, hovering around 750 - 775 rpm and feels rickety when it dips low, you can feel the vibration through the whole car. Could this be engine mounts? Does it have an ISV like the 944?
Also the oil pressure guage kept spiking for no apparent reason, it was at about 7 (i'm assuming not bar?? That kpa(?) reading, im not sure [
]) when sat idling but would suddenly spike to 10 (maximum of readout) for a second then go back to normal. Guessing again, would this be more likely to be the sender and not a problem with the engine?
