Just brought the SPYDER out of hibernation ,I have what looks like a fault .1 When I reset the clock to the correct time and then start it up it goes back to either 9.00 or 12.00 . 2. Just went to fill it up with some fuel as was showing check remainder range ,put in £40 worth still showing check remainder range ,it is on a charger has been for a long time prior to starting it up ,is a bit labored on turnover ,is the battery on the way out after 10years ? what should the voltage show as minimum and max .Have just reconnected it back up to the Lidl charger has been used since day one on storage no issues to date suspect battery as opposed to charger not working .Any thoughts are these faults listed down to low voltage ?
Thanks in advance
Thanks in advance
