Lower balance shaft rear seal.
- Thread starter James0
I've heard some people on rennlist have used a good sealant applied to the outside of the rear seal with some success without the need to dismantle the cover.
Waylander
that works but its a bit messy, my car had already been gummed up with black RTV when I got it, and guess what it still is, its a real pain in the $%^& to get at and you have to take all the front off again to get it off,dlknight said:I've heard some people on rennlist have used a good sealant applied to the outside of the rear seal with some success without the need to dismantle the cover.
I replaced my top one with a nitrile seal so it shoukd last a bit longer, there is no real pressure in there so RTV works a treat
PSH
Pete
I'm doing the belts and engine mounts anyway but I'm not overly happy having the engine open like that whilst still in the car. I'm a bit worried about keeping dirt out.
Waylander
and if you want to try forcing another o ring in the end I would just go buy a box of cheap ones from Aldi or Lidl all nitrile and £4 a box
999 701 875 40 £2.45
and i agree I would be worried about ingress of dirt/grit as you have to take off the belts, rear covers, power steering pump, front housing which will involve more new seals, balance the engine as the OS engine mount and bracket will have to come off too and possibly the steering shaft,
and for those that struggle with Locktite 574, slap it on then spread it with a foam mini roller you need so little, honestly
It's probably a better solution than the original oring, if it leaks I'll change the oring and use sealant when I do the engine mounts, belts, front hubs etc etc.
Thanks all.
