lowered sussies
964rh
Any recommendations on lowering a 964 C4?
How much are you looking at to get someone to fit parts and reset geometry?
Rob
Eibach springs 30mm lower and Bilstein HD shocks plus wheel alignment by Parr - from memory about £1500.00
Great set up.
would buy this if i could afford it - http://www.9mracing.co.uk/html/modules.php?op=modload&name=Shop&file=index&req=viewproduct&productid=2818&category=0&parentid=0
Springs and shock well out of my price range at the minute. Trying to ho the wife to get some though[:D]
Keith,
Have you got the H&R on your 964, a couple of companies i've spoken to said to go for the Eiback progressive springs rather than H&R, is it worth paying the extra dosh for these or are you happy with yours?
Rob
h&r are progressive and seem ok, i would like to go lower but too many speed bumps around, strangely on the approach to many racetracks!!
Rob,
give me an email, I might have a source for H&R and Bilstein B6 sports, not fitted, but costing around £570+vat.
kevin
Hi Rob
I've just got myself a set of H & R's which came highly recommended from a friend. I was going to have a go at fitting them myself and then get the set up settings done by Micheldever Tyres who've quoted £150 approx. They've done loads of Porsche alignments and were recommended by the OPC.
I'll let you know how it goes.
Are you embarking on some other handling mods? I'm thinking of a strut brace too?
Good luck
Steve
Steve,
I think I will be going with the H&R springs. Just can't afford a full spring and shock changover at the minute as it looks like the heater prob. I've got is going to cost a fortune. I would like to know what you think of the springs, I won't be getting them for a few weeks so feed back would be appreciated.
I've heard a lot of good reports about strut braces (on the 964RS register I think) so I think I will get one fitted at the same time at the springs.
Be careful fitting them yourself as I read on another post that the geo. setup was affected that much when fitting that someone lost about 4mm of tyre tread taking to get setup!
Rob
Hi Rob
I'm taking some advice from a man who knows........
Don't fit the lowering springs at the same time as the strut brace - that way you get to sample 2 separate improvements individually!
I'll be fitting the springs as soon as I get some space in a friends workshop. I'll let you know how it progresses and hopefully describe any benefits.
I'm getting a bit fed up with the high-rise 4 X 4 look!
Steve
ORIGINAL: steve bright
You and me both Steve,
One of the things that made me look into this was having a sprayer 'friend' of mine look at the front of the car and laugh at the height it was sitting. Just before I could get to the 'yeah well at least I've got a Porsche to ride high' comment he brought out my fav. looking car that he'd just brought....dark grn DB7. B*ST**D.
Rob
Hi All
Fitted some H & R lowering springs on Monday and the car now looks exactly as it should - in my view! The changeover was quite easy and went really well. A few minor disconnections in the engine bay for access was about all, and then a straight one-for-one exchange. I also cut the bump stops down by 30mm. The front top mounts proved a bit awkward to un-do but the surrendered in the end.... Fortunately all the bushes seemed good and the dampers were ok so there were no extra hidden cost lurking.
Not many miles coverd since but very pleased so far. I'll be able to give a proper report after the alignment check this afternoon. I can say that the ride hasn't become really harsh or crashy and it has kept the civilised feel, albeit slightly harder.
I'll let you know how the alignment goes.
Steve
Had the car laser aligned by NH Autos in Blandford Forum yesterday - WHAT a transformation! The car handles really well and feels better than it ever did. Chuffed to bits with the results and feel that it's been money well spent.
Steve
