Lowering Springs
- Thread starter Guest
Richard Knight
030 is the prefix for the "sports suspension" option. This option includes ,10mm shorter springs, uprated anti roll bars and stiffer shock absorbers.
It effectively lowers your car by 10mm and gives you better road holding/body control. But you sacrifice ride comfort in doing so.
I have this option on my MY2001 S . I have also had even shorter progressive springs fitted as well. So my car sits about 30-35mm lower than standard.
It does not like multi story car park ramps, speed humps etc.
Food for thought!! Cheers Richard.
The look of the lowered car is great - much more purposeful. The ride on my 03 S with 18" wheels is already firm, but as our mileage is quite low I think I could stand it a bit hasher still. But as for the speedbumps - when I was out today I found myself in a one way street looking straight at a line of bumps ahead - What would I have done with the lowered car????[8|]
Julian
Richard Knight
It's not a major drama to avoid tight multi story car parks etc and I've not found a speed bump that I've not been able to safely negotiate yet.
I think the benefits far out weigh the negatives.
I took her out for a 3 hour blast up into the mountains yesterday afternoon. Top down , woolly hat the works! The Italian job on acid. Pure magic.....
Richard.
The new adjustable suspension seems like the answer. My wife has air in her KN S and I love it.
dawn lang
Ex Club Member
Personally I found it a little too hard - perhaps something to do with the mixture of the lower suspension and 18" wheels! [8D]
Brian
ORIGINAL: b3sun
Hard braking especialy over humback bridges causes the nose to bottom out far too often for my liking. It means I have to adjust my driving much more than when I had the sports suspension.
This is a comment I would like to understand better: If you are braking after the bridge (so the car is effectively decsending on its suspension which is presumably why it bottoms under hard braking) then there must be a second hazard immediately beyond the bridge for which a lower speed is needed when you approached the first hazard, i.e. the bridge. If you cannot see over the bridge to plan for the second hazard then maybe the bridge is taken at the wrong speed?
I don't understand how the scenario arises otherwise.
I'm curious about what way you are adjusting your driving?
Andrew
Carl.Young
ORIGINAL: b3sun
Bottoms out? I have an S on 18" wheels / standard suspension and tend to be positively airborn (and in fits of laughter) over a particularly tall crest near where I live. I've not bottomed the car yet. The only time I've found anything wanting in body control tends to be at very high speeds. On private roads of course. []
I'll rephrase my comments.
When I drive hard and fast the nose of my "S" with regular suspension bottoms out far more often than did my 2.5 with sports suspension.
I therefore have to moderate my driving to a degree. I particularly notice this problem when driving hard on twisties in France.
The solution seems to me to be adjustable suspension as on my wifes KN. A degree of comfort for cruising and around town and hard stiff suspension for the twisty bits.
Perhaps Porsche should take a look at the set up on the "S" in question. My mk 1 2.7 with standard suspension has never bottomed, not even round the Alpine route at Milbrook where there are also some pretty nasty NVH testing strips as well as rapid changes in gradient. I've driven a mk 2 S across some of the roads in Cambridgeshire and Norfolk and didn't notice any errant behaviour. I'm guessing some of those fenn roads are similar to those you mention in France.
Sounds like you might have favoured PASM in retrospect?
Andrew
