ORIGINAL: lali
ORIGINAL: Neil Haughey
Anyone on here have experience of what an NA is like on the track with an LSD fitted? The reason I ask is that even in the dry at Bedford this weekend I was getting the inside wheel (left) spinning up when changing from 2nd to 3rd gear after turn 1.
Is this still on the "west" circuit layout?
I agree with your later comment that its better as a 2nd gear corner but I only used to get the wheel spinning on one of the last corners on the GT circuit.... ( the right hander after the really tight hairpin )
Try a wider exit line... (the drain on the exit kurb should pass under the middle of the car) might help you get the power down.
I've got an LSD now so its all about understeer now.
