looking to fit a LSD to a 915 Box any advice etc
LSD to a 915 Box?
- Thread starter carreraboy
how about http://www.quaife.co.uk/Porsche-911-43T-Quaife-ATB-differential
Its a helical diff, so not fully locking like a plated diff though. Probably smoother though.
Thanks ... picked the car up tonight ... wheelspin in 2nd! With moderate acceleration...
These are meant to be good.
http://www.racecar.co.uk/gripper/apps.htm
You can choose your own settings too IIRC. 60/40 is meant to be a good compromise for street and track. The other factor is the preload (the tq before it slips), I forget the advised number but it is much higher than what the stock Porsche diffs used, twice as high IIRC.
ZF LSD being fitted soon ... with a 40% lock/slip as I will be Touring with the occasional Track Day as opposed to a 80% lock/slip very Track Day focussed .... any comments ........[8|]
If it was a road car I would go with the helical, nice & progressive, no jerkyness and no friction plates to wear.
For a track car, the plated diff has got to be the choice, more lockup, adjustable.
But for a compromise ?, probably the helical. Subaru & Mistsubish get good results from them, and put a lot of torque through them.
william inch
Would someone be able to tell me what the original option code for the lsd would be on a '84 3.2? I assume this should be in the list of options on the sticker in the original service book.
Many thanks
W
Many thanks
W
Des, is that the stock Porsche part?
Told yes
You might want to get it tweaked to increase the tq before it starts to slip.
