LSD
- Thread starter Logie
Out of interest, what was the option code for it on an S2?ORIGINAL: mik_ok
No.
Turbo250 had it as std, was an option on S2. No idea prior to that. []
Neil Haughey
DivineE
p.s. Obviously if you can find an LSD option box, on a car being broken, with a good diff in it still then that's fantastic but I've been there twice and ...well good luck is all I can say!
Jonny944CS
Initially I was curious too. I fitted a second hand turbo LSD (40% plate style) that I managed to snap up from ebay for ÂŁ150 some years back. The unit is getting on for double the weight of the open diff (but the part numbers for the friction plates do start 917 XXX XXX XX [
Anyway, the first thing that stuck me was how by just changing the diff a nice neutral handling car had now developed a strong leaning towards understeer. Also, up to a point, it became less 'playfull' around roundabouts. On the track it gave the car rock solid stability on turn-in and exit, but after a while I found that a little dull to be honest.
One thing I would say, is that it was fantastic on track in the wet. It gave loads of confidence and predictable understeer, allowing you to commit without fear of getting into a tankslapper.
After a bit of fiddling I've found a better balance in the dry by running the rear arb much stiffer, though I get the feeling I'm papering over the diff characteristics, rather than improving the car over the open diff starting point.
In conclusion I would say the 160hp of the 2.5 isn't quite sufficient to make best use of an LSD. I tended to notice more of the downsides than the upsides.
djaychela
sawood12
Neil Haughey
ORIGINAL: Jonny944CS
That would be what I expect TBH you would have little choice but to adjust the suspension setup after fitting an LSD, perhaps increasing the rear spring rate substantially. The problem then is that you have to change how you drive the car not just to make it work well but to get the most out of the car. Certainly talking to those racers who have a broad experience across both say a non LSD S2 and a 968 fitted with an LSD is that the cars are surprisingly different to drive.
Jonny944CS
With the LSD I could be more agressive with trail braking and picking up the throttle early. Great for the chicanes at Castle Combe, not so good for the long fast sweepers of Silverstone.
Maybe what I need is a MAGIC PADDLE like Mr Schumacher, then I could adjust for every corner...
Intersting that the new Mclaren road car doesn't have one fitted, relying instead on clever application of the rear brakes to control traction.
Neil Haughey
Some drivers though like the car to move around a lot I don't.
If your suffering under-steer just after the apex you can tune that out by increasing the rebound on your front shocks, I am thinking the corner your referring to is something like Copse where its very easy to run out of track.
No doubt about it though its not as simple as just putting an LSD on a car.
Jonny944CS
Something I'd like to try - though I find changing the rear toe/camber in my garage can be akin to pushing poo uphill with a small stick...Probably change the rear toe setting as well then
I'm currently running with virtually zero toe at the rear, would adding lots of toe not increase tyre scrub on a permanent basis?
Yes, Copse and also Stowe in particular.If your suffering under-steer just after the apex you can tune that out by increasing the rebound on your front shocks, I am thinking the corner your referring to is something like Copse where its very easy to run out of track.
Definately one to try during the 944 group meeting/track evening on June 20th.
http://www.porscheclubgbforum.com/tm.asp?m=623728
Neil Haughey
DivineE
ORIGINAL: tr7v8
If you really want an LSD I have a S2 box here with LSD for sale
That would be the perfect option I reckon as you'd get the shorter ratios.
