M030 Calliper?
- Thread starter bennyboy
Copperman05
Edd
Copperman05
Edd
Big Dave
ORIGINAL: edh
they would have had to have swapped the whole hub/strut assembly over.
No they wouldnt. As adapter brakets are available....
Copperman05
944 man
Neil Haughey
ORIGINAL: Big Dave
ORIGINAL: edh
Maybe only the spindle needed, or rather steering knuckle in PET speak? The 968 M030 also had different hubs but are they required?
Big Dave
ORIGINAL: 944 man
Id say that you have to change it all, but thats to run the struts and caliper and rotors. Perhaps Dave means that the calipers alone can be run on a car utilising adapters?
Correct that man...
Yes you can fit JUST the [M030]caliper to the standard NON M030/turbo spindle using a adapter bracket/plate...
Ive done this on my car , with no probs whatsoever...
In fact if anybody wants a pair of these adapters, please PM me + ill see what i can do....[
paulf968
NB of course it is important that the new thread is concentric with the actual bleed hole in the caliper otherwise the bleed valve will not seal !
