M030 technical question
- Thread starter DivineE
951 S & Big Black/Red piston size is the same thoug.
sawood12
944 M030 'Medium blacks' are smaller than big blacks/reds and had fit behind 16" wheels. They have the same piston diameter as the big red/blacks but smaller pad.
There is nothing wrong with the use of adaptor brackets, they work fine, so no need to search high and low for a pair of M030 hubs, most of which you'll find of broken cars that have been in crashes so the integrity of which you wont know. I'd rather stick with the hubs I have and use bracket adaptors.
DivineE
Would you recommend the Lindsey Racing adapters? I heard they had a problem with clearances against the suspension strut or something? Also isn't the offset of the disk centre different on the Early 944 turbo? Would you still be able to use the 964 turbo/ 968M030 combination?
This would obviously be by far the best and most economical solution if it's possible but would like to check it works before I start buying parts!
sawood12
You need to remove the disk baking plates. I guess if you really wanted to retain them you could buy the plates off a 928GTS and install those, but to fit you need to dismantle the hub. There is no detrimental effect to the removal of these plates apart from getting brake dust over the suspension wishbone.
I don't believe there is an adaptor kit available for the early offset cars. For these you'd need to replace the lower control arm, front hub to get the later offset.
I bought the entire Lindsay Racing Big Black kit that comprised of brand new calipers, caliper adaptors, OEM 928GTS disks, SS braided brake hoses, front and rear pads. All for $1500 which back in the day when you got $2 to the pound was cheaper than I could get a tatty pair of used Big Red calipers off ebay. It is ridiculous how much people are prepared to pay for tatty used stuff off ebay.
If I were to do it over again i'd give Boxster S calipers a go. They are far more plentiful and cheaper on ebay and there are kits now available.
DivineE
ORIGINAL: sawood12
Ooh where from? Thank you very much for all the info by the way. My car is early offset so this does complicate things but just to clarify for the record 'if' you do change the hubs to the M030 type you can keep the original wishbones and wheels to keep the early offset without upsetting anything. (only found this out because I bought a car with this conversion already installed).
Also another point for the record the 'Big Blacks' don't fit in the 16" wheels. I know you said this above but I tried it for real to make sure it wasn't a rumour and it didn't fit
DivineE
ORIGINAL: 944 man
Beware of rear calipers being sold as fronts, by unscrupulous vendors. The rears have a smaller piston surface area so they will do less work, even where similarly sized.
Do you mean on the with the Boxter S callipers of with standard 944 parts?
