M030 underbits
- Thread starter craig2105
sawood12
Later TurboS cars had the LSD gearbox and uprated brakes as standard so the M030 upgrade was the Koni suspension.
ORIGINAL: sawood12
..... uprated ARB's (rear one is adjustable).....
I thought that was only if you have 968 M030 rear ARB's?
edh
Suffolk944
Moderator
sawood12
ORIGINAL: sawood12
Without a shadow of a doubt, no matter what model of 944 you have, if there is only ever one mod you do to your car ever then it must be KWv3. It will transform your car in every conceivable way. Superb and not that expensive despite what people think. It is the cost of a decent Mountian Bike if you install properly and a half decent one if you don't. Forget MAFs, chips, air filters, turbo's, ARB's, LSD's, M030 you'll get much much more out of the KW.
Who set up your geo ?.
sawood12
If i'd have kept the car longer then i'd have had the geo reset. The specialist I use - Zentrum, do a thing where you take the car just before a trackday and he will set it up depending upon a description of how you want your car to handle, you take the car on a trackday and take it back afterwards and he will re-adjust for free if you want it tweaking. If you pay more money (alot probably) he'll even come on a trackday with you and tweak the car track-side through the day. He's done alot of racecars in his time.
craig2105
ORIGINAL: sawood12
Initially Promax, who installed it but earlier on this year I got the front raised a bit as Promax set it at quite a nose-down attitude and the geo was checked and tweaked to correct for the raised nose. Settings were as standard but towards the extremities of the tolerances to enhance road holding, and even at these more-road orientated settings the car felt great - planted, really really good body control.
Thanks,
Zentrum's a bit too far away for me, there seems to be a few places with the gear but I'm not convinced they all know how to use it, if it's still a month + wait at Centergravity I will have to try someone else.
