Macan Turbo brake pad size
CM_P
Hi all, I have a 2017 Macan Turbo - there seem to be a few front brake options based upon disc diameter size (390, 350 or 345mm), other than taking the wheel off to measure the diameter - is there a way to identify which brakes to purchase ?
thanks in advance.
Carl
Fronts are 360mm I think. Turbo and GTS bigger than other models hence smallest wheels won’t fit these models
Check with the seller
