idwoodvale
Is anyone running a NA car with the Deutsche Nine MAF kit? The website says it is a Bosch system.
I've been deliberating for a while as to whether the 944 stays or not as I've been having albeit minor running problems and she is in need of some body work TLC. The running problem - runs rich at idle and can be hesitant to say the least at 5k and above - really bad flat spot (at times). Roger at Promax suspects the AFM may be responsible. If this proves to be the case then I may be in for a new one costing around 500 quid. I know that Roger and Andy used to supply a similar kit but no longer do so due to probs running them on the 944.
All this depends on whether I feel I can put all the necessary money into the car so a little advice would be appreciated. I've been looking at several cars to do the work of the Volvo and the 944 together - i.e. be reliable and cheap to run, quick and make me smile (not alot to ask![
]). Nothing has yet done this enough to persuade me to change. Plus the depreciation on a newer car negates half the incentive.
