Hi all,my 2000 C4 has recently had the problem of the ABS and TC lights coming on,first port of call will be the MAF sensor.Looked at removing it tonight and found that the screws aren't of the torx type but some sort of security screw,can anyone tell me what type they are and who would supply a bit for them,thanks for any help.
MAF sensor removal.
- Thread starter gazzy
thirteeneast
I know you probably know but careful what you clean it with.[]
thirteeneast
Personal I use Switch cleaner, Carb cleaner, Brake cleaner or Isopropanol.
However some insist on Maf cleaner that is available in cans, I fail to see how it can differ from the above.
I have also never damaged a MAF using any of the above.
Sorry if I sit on the fence, But MAF sensors aint cheap!. LOL.
Are you sure switch cleaner doesn't have a lubricant in it? Best check first.
thirteeneast
Yep,
Some switch cleaner is cleaner & Lube and some is just cleaner yes.
But it says on the label so read it first.
thirteeneast
thirteeneast
Sure
