I am going to have my magnesium wheels refurbished and have been gathering opinions / info from people to try and work out what my options are and where to go. Up until last year the place to go seemed to be Diamond Styling - not cheap but I have seen Chris's work and it was fantastic. He has sold his business now and jury is still out on the new guy.
Quite a few companies will not refurbish Magnesium wheels for two main reasons. Firstly, unlike most alloy wheels they are deemed to have a limited life and will deteriorate with age (now 15 years old) so when companies refurbish them they often find problems when they strip the wheels. Secondly, the wheels are porus and can absorb moisture when not treated/painted correctly and due to problems witrh the finish they have a high number of returns.
The basic things to look out for appear to be:
- if blasting the wheels to remove paint, use of soft/pearl beads to sand blast to maintain detail eg lettering on the wheel
- minimise time exposed to air / moisture after stripping but before painting to reduce the amount of moisture absorbed
- heat the wheel before painting / powder coating to remove all traces of moisture otherwise the finish will bubble / flake when the wheel heats up on track
- do not paint/coat the mating surface especially if the wheels are to be used on track
When talking to refurbishing companies who take on magnesium wheel, it becomes very obvious who knows what they are doing vs those that will treat them like other alloys. The two options for colouring the wheels appear to be paint or powder coating followed by laquer. There are pros and cons with both.
Paint
+ original finish (check paint code), clarity of lettering, can be sanded during prep for better finish
- more expensive (labour cost), less durable
Powder coating
+ very durable, process removes moisture
- coating is thicker so some clarity of lettering can be lost, not original
Ollie had his wheels painted by Jasmine and he is very happy with the result - I am hoping to have a good look at Donington next week. I have also seen a set that have been powder coated by a company called BJV Engineering that were also very good. Paint finish is approx twice the price of poweder coating.
I thought I would post this for two reasons - share info as it seems to be a minefield and also to see if anyone has any other information / experience before I take the plunge.
What do you guys think?
Paint
Powder coating
