main beam problem
delboy
Have a problem with offside main beam. Light was flickering whilst driving ths morning (when I went over bumps), and now it doesn't work at all. Have swapped bulb with a working one, but still no good. Checked fuses and they are OK. High beam works
Any ideas?[:mad:]
Hi,
Possible bad earth or broken cable check for power at plug end with multi meter or bad / dirty connection on headlamp plug if all ok and power present buy brand new bulb incase you have damaged other blub when changing around.
Hope this helps
I have experienced the pins in the multiplug connection melting where the plug goes into theback of light unit................if u cant fix it, with a little wiggling etc new one sorry!
Thanks all
It was not seated properly into the plug.. Checked with a meter and the Voltage was there (at the plug), and the bulb was good. Thanks for your help
