Main beam warning light
- Thread starter ronjan
vitesse
Try a test lamp attached between the lampholder input terminal & earth with the lights switched between low/high beam-if it lights up ,then move the probe to the input set of lamp contacts(with the bulb removed)-leave other test lead earthed-if OK,move earth probe to output set of contacts leaving other test probe on the input contactset-if OK,then faulty bulb indicated
