wolfie308
Got home earlier from a couple of days in Wales and a spritely and enjoyable return without problem. Stopped to pick up some bits and pieces locally, and when I came back to the car and started, I noticed the main warning light was on. At first I thought it was the hand brake which had been used hard several times to ascend the steep drive from the cottage where we'd been staying. Hand brake shoes were replaced recently and works fine although could do with a bit of adjustment.(Park brake light goes out when hand brake released) Thought if could be oil or water, but checked levels of both and all fine and no other secondary lights are lit. Have left it for a couple of hours and tried again, but still the same.
Bit of a puzzle, so any suggestions most welcome as I'm a bit worried about using before resolved
