My 944 has a recurring problem with its cooling system.
This last couple of weeks, cos of the cold weather, in normal driving the temp gauge sits firmly on the first line on the gauge and i get good heat through the vents. Soon as I come into traffic the gauge rises rapidly but the fan doesnt come on and I either have to turn off or pray for a gap in the traffic! I have put a new relay in 2 weeks ago.
Today I went to London and back - about 160 miles and soon as I hit the M25 queues the gauge went up but I was prepared with a 5 litre can of water and pulled off to watch from the engine bay. The top hose and lower hose from the rad dont seem too hot yet the gauge is near the top. In fact there didnt seem much water in those hoses as I could squeeze them up easily!.
I carefully took off the expansion tank cap and the water started to overflow after a couple of minutes so I turned off and refilled.
Driving home I noticed a faint smell of coolant fluid but water level is good and no overheating.
I've also noticed the exhaust seems to have a lot of vapour in it yet there is no sign of water in oil or vice versa.
2 things - a) does this sound like a problem coming up and b) should I wire up the fan manually anyway?
